Introduction
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
Ce dont vous avez besoin
Étape 1 Cardinal Health Vela Ventilator Power Cable Removal
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme étant en cours.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Étape 6 Cardinal Health Vela Ventilator Battery Tray Removal
Attention : les étapes 6 à 8 sont issues d'un tutoriel marqué comme étant en cours.
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Étape 13 Blender Assembly P/N 16358A
Attention : les étapes 13 à 21 sont issues d'un tutoriel marqué comme étant en cours.
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
