Aller au contenu principal
Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement
Ce dont vous avez besoin
  1. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: étape 1, image 1 de 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: étape 1, image 2 de 2
    • Unplug the unit before disassembling to avoid electrocution.
    • Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
  2. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: étape 2, image 1 de 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: étape 2, image 2 de 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: étape 2, image 3 de 3
    • Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
    • With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
  3. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: étape 3, image 1 de 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: étape 3, image 2 de 2
    • Once you have the halves opened at least 1/4'', remove the metal key and rotate the base a quarter turn in any direction.
    • Continue using the spudger to pry open the base at each quarter turn until the sides separate easily.
    • The black bottom will catch on the power cord plug, to prevent total dismantlement.
  4. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: étape 4, image 1 de 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: étape 4, image 2 de 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: étape 4, image 3 de 3
    • To uninstall the element, start by removing the 4 copper connectors and 1 metal tab from the power cord. This will require you to wiggle and pull the connectors out.
    • Once those pieces are detached, you can insert them into the replacement part, as they were.
2 autres ont terminé cette réparation.
Melanie Preston
Membre depuis le 07/01/17
113 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G3, Liner Summer 2017 Membre de l'équipe UW Tacoma, Team S1-G3, Liner Summer 2017
UWT-LINER-SU17S1G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 437
