Introduction
Located between the power source and the boiling arm, this safety mechanism automatically shutsoff the flow of power when the kettle is uncoupled from the base.
Ce dont vous avez besoin
Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
To uninstall the element, start by removing the 4 copper connectors and 1 metal tab from the power cord. This will require you to wiggle and pull the connectors out.
Once those pieces are detached, you can insert them into the replacement part, as they were.
2 autres ont terminé cette réparation.
