Aller au contenu principal
Carrera Mario Copter Motherboard Replacement
Ce dont vous avez besoin
  1. Carrera Mario Copter Motherboard  Replacement, Battery: étape 1, image 1 de 1
    • Flip the quadrocopter over so that the underside of the device is facing up.
    • Unplug the battery cable from the socket on the quadrocopter.
  2. Carrera Mario Copter Motherboard  Replacement: étape 2, image 1 de 1
    • Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
  3. Carrera Mario Copter Motherboard  Replacement: étape 3, image 1 de 1
    • Pull the battery away from the slot to remove it.
  4. Carrera Mario Copter Motherboard  Replacement, Motherboard: étape 4, image 1 de 2 Carrera Mario Copter Motherboard  Replacement, Motherboard: étape 4, image 2 de 2
    • Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
    • Remove the entire black circle base and flip it over so you can see the motherboard.
  5. Carrera Mario Copter Motherboard  Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers remove the four white heads wires from the motherboard.
    • Be careful not to cut the wires plugged to the little white heads. Grab onto the plastic connectors if possible.
  6. Carrera Mario Copter Motherboard  Replacement: étape 6, image 1 de 2 Carrera Mario Copter Motherboard  Replacement: étape 6, image 2 de 2
    • Using the tweezers remove the golden head screws that hold down the motherboard.
    • Hold strong the motherboard and pull up strong the head screws.
    • Be careful not to hurt yourself. You will need to try several times to remove those.
Stephany Martinez
Membre depuis le 10/23/17
122 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G6, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 10
Total : 333
