Aller au contenu principal
Casdon Dyson Ball On/Off Switch Replacement
Ce dont vous avez besoin
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: étape 1, image 1 de 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: étape 2, image 1 de 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: étape 3, image 1 de 1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: étape 4, image 1 de 1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: étape 5, image 1 de 1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: étape 6, image 1 de 1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: étape 7, image 1 de 1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
Seldon Price
Membre depuis le 11/07/17
612 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 membres
10 tutoriels rédigés
Un commentaire
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 2,064
