Aller au contenu principal
Casio CTK-501 Battery Connection Replacement
Ce dont vous avez besoin
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: étape 1, image 1 de 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: étape 1, image 2 de 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: étape 2, image 1 de 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: étape 3, image 1 de 2 Casio CTK-501 Battery Connection Replacement: étape 3, image 2 de 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: étape 4, image 1 de 1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: étape 5, image 1 de 1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: étape 6, image 1 de 1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: étape 7, image 1 de 1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: étape 8, image 1 de 1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
3 autres ont terminé cette réparation.
Jimmy Winne
Membre depuis le 10/04/12
578 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 9-16, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 4,728
