Introduction
This guide will show you how to detach the lens assembly from the camera. You may have to repair or replace a cracked lens or one that won't retract.
Pièces
Aucune pièce nécessaire.
  1. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
    • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  2. Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
    • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  3. Separate the front case from the body of the camera.
    • Separate the front case from the body of the camera.
  4. Separate the back case from the body of the camera.
    • Separate the back case from the body of the camera.
  5. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  8. Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  9. Continue to lift the LCD screen all the way up. Be careful not to rip any wires connecting the LCD screen to the top of the camera.
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  10. Remove the orange ribbon cable by grabbing the white tab and pulling back. Remove the orange ribbon cable by grabbing the white tab and pulling back.
    • Remove the orange ribbon cable by grabbing the white tab and pulling back.
  11. Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver. Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
    • Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
  12. Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
    • Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
  13. Once the bottom portion of the camera is removed, stand the camera  upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
    • Once the bottom portion of the camera is removed, stand the camera upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
  14. Fully remove the lens from the motherboard.
    • Fully remove the lens from the motherboard.
    • It will still be attached by wires and a different orange ribbon cable.
    • You can now proceed to repair the existing lens or replace it with a new lens.
Greg Bucher
Membre depuis le 19/04/2012
14 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-45, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,028
