Introduction
This guide will allow you to properly replace the front and back panel of the Casio Exilim EX-Z80 camera. This will also allow you to access the inner parts of the camera in the case that the lens or motherboard need to be replaced.
Ce dont vous avez besoin
Locate the battery compartment at the bottom of the camera.
With your thumb, gently press down on the compartment door and slide to the left to open.
Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
Open the battery compartment with your thumb or index finger.
Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
