Introduction
Welcome to this Fast Fix guide on how to replace the CR2016 Lithium battery in a Casio F91-W watch. The Casio F91-W is a popular digital watch known for its affordability, durability, and simplicity. However, like all electronic devices, the battery will eventually run out of power and require replacement. Fortunately, replacing the battery in the Casio F91-W is a straightforward process that can be done with just a few basic tools and a new CR2016 battery. In the following guide, we will walk you through the step-by-step process of replacing the battery in your Casio F91-W, so you can continue to enjoy your trusty timepiece for years to come.
Ce dont vous avez besoin
Place the watch with the digital display facing downward, revealing the back cover.
2 autres ont terminé cette réparation.
Un commentaire
Fantastic guide, thank you! On reassembling I did find I had trouble getting the watch movement back in the case. This was because the buttons were catching on the button arms. To solve it I used a flat head to push the buttons out, from the inside, as far as they would go and with a bit of persuassion it all went back in. Thanks again :-)
