Introduction
In the event that your battery dies, you will need to replace it. This guide will show you how.
Ce dont vous avez besoin
Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
5 autres ont terminé cette réparation.
