Aller au contenu principal
Casio G’zOne Commando 4G LTE Motherboard Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: étape 1, image 1 de 1
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: étape 2, image 1 de 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: étape 2, image 2 de 2
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: étape 3, image 1 de 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: étape 3, image 2 de 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: étape 4, image 1 de 3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: étape 4, image 2 de 3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: étape 4, image 3 de 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: étape 5, image 1 de 1
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: étape 6, image 1 de 3 Casio G’zOne Commando 4G LTE Motherboard Replacement: étape 6, image 2 de 3 Casio G’zOne Commando 4G LTE Motherboard Replacement: étape 6, image 3 de 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: étape 7, image 1 de 1
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: étape 8, image 1 de 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: étape 9, image 1 de 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Gently remove the motherboard with the spudger.
4 autres ont terminé cette réparation.
Brett Boehm
Membre depuis le 09/25/14
281 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 853
