Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
Ce dont vous avez besoin
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: étape 1, image 1 de 1
      • Slide the slider on the back of the phone to the free position.
      Demander à FixBot
      Ajouter un commentaire
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 2, image 1 de 1
      • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
      Demander à FixBot
    3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 3, image 1 de 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 3, image 2 de 2
      • Pull the white battery tab upwards and remove the battery.
      Demander à FixBot
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: étape 4, image 1 de 1
      • Remove the four 6mm Y0 screws from the corners of the device.
      Demander à FixBot
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 5, image 1 de 1
      • Remove the four 5mm Y0 screws from the back of the device.
      Demander à FixBot
    3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 6, image 1 de 1
      • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
      Demander à FixBot
    4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 7, image 1 de 1
      • Lastly, using your hands, separate the motherboard from its compartment.
      Demander à FixBot
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: étape 8, image 1 de 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: étape 8, image 2 de 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: étape 8, image 3 de 3
      • Using a spudger, gently lift up the orange connector.
      Demander à FixBot
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 9, image 1 de 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: étape 9, image 2 de 2
      • Flip over the motherboard
      • Using a spudger, lift up the small black connector and remove the camera.
      Demander à FixBot
Zack Almeida
Membre depuis le 10/24/18
392 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 membres
58 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 27
Total : 426
