Aller au contenu principal
Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement
Ce dont vous avez besoin
  1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 3, image 1 de 2 Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 3, image 2 de 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 5, image 1 de 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 6, image 1 de 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: étape 7, image 1 de 1
    • Lastly, using your hands, separate the motherboard from its compartment.
Zack Almeida
Membre depuis le 10/24/18
392 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 181
