Aller au contenu principal
Casio MTD-120 Battery Replacement
Ce dont vous avez besoin
  1. Casio MTD-120 Battery Replacement, Battery: étape 1, image 1 de 1
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: étape 2, image 1 de 2 Casio MTD-120 Battery Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: étape 3, image 1 de 2 Casio MTD-120 Battery Replacement: étape 3, image 2 de 2
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: étape 4, image 1 de 1
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: étape 5, image 1 de 1
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: étape 6, image 1 de 2 Casio MTD-120 Battery Replacement: étape 6, image 2 de 2
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: étape 7, image 1 de 1
    • Put the cover back and tighten it shut by pressing on it.
Follow the link provided in step 5 to find more information on recycling your old batteries.
2 autres ont terminé cette réparation.
Isabel Chavez
Membre depuis le 01/16/20
193 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 29
Total : 4,591
