Aller au contenu principal
Casio MarineGear wristwatch battery Replacement
Ce dont vous avez besoin
  1. Casio MarineGear wristwatch battery Replacement, Opening the back: étape 1, image 1 de 2 Casio MarineGear wristwatch battery Replacement, Opening the back: étape 1, image 2 de 2
    • Use a Phillips #00 to remove the 4 screws holding the back.
  2. Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: étape 2, image 1 de 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: étape 2, image 2 de 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to remove the plastic ring that aligns the movement.
    • In this case the watch didn't have a battery installed, but to get the battery out you have to use the tweezers and unhook the latch holding the battery in place.
    • The correct battery for this watch is CR2025 3V button cell.
  3. Casio MarineGear wristwatch battery Replacement, Install new battery: étape 3, image 1 de 2 Casio MarineGear wristwatch battery Replacement, Install new battery: étape 3, image 2 de 2
    • Insert the new battery into it's place.
    • Latch the battery hook back into it's place, securing the battery.
    • Turn the movement over to verify the watch is now working.
    • You may have to touch the AC (negative) side of battery, to the metal grounding plate. (It's stated on the white label and marks are very clear).
  4. Casio MarineGear wristwatch battery Replacement, Reassemble the watch: étape 4, image 1 de 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: étape 4, image 2 de 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: étape 4, image 3 de 3
    • Make sure the rubber gasket is placed correctly in it's groove, as it is there for water resistance.
    • Place the back cover on and fasten the 4 Phillips #00 screws securing the back plate.
    • Set the time and date, and your watch is now in working order again.
Reassembly is detailed in the guide
Geir Ove Andersen
Membre depuis le 06/06/22
7 815 Réputation
5 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 525 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 32
Total : 1,148
