Aller au contenu principal
Casio SPF-40 2273 Battery Replacement
Ce dont vous avez besoin
  1. Casio SPF-40 2273 Battery Replacement, Battery: étape 1, image 1 de 3 Casio SPF-40 2273 Battery Replacement, Battery: étape 1, image 2 de 3 Casio SPF-40 2273 Battery Replacement, Battery: étape 1, image 3 de 3
    • This super strong Casio watch is more docile than waht you might think.
    • We don't need to twist off the front's screws.
    • It doesn't bite, so let's turn it around
  2. Casio SPF-40 2273 Battery Replacement: étape 2, image 1 de 3 Casio SPF-40 2273 Battery Replacement: étape 2, image 2 de 3 Casio SPF-40 2273 Battery Replacement: étape 2, image 3 de 3
    • With the phillips screwdriver take off these four screws
    • Lift up an extremity of the watchstrap and remove the base.
    • You can use a flat screwdriver to help you
    • With the tweezers lift the white plastic cover
    • Be careful to not damage the golden springs!! So take your time
  3. Casio SPF-40 2273 Battery Replacement: étape 3, image 1 de 3 Casio SPF-40 2273 Battery Replacement: étape 3, image 2 de 3 Casio SPF-40 2273 Battery Replacement: étape 3, image 3 de 3
    • With the tip of the tweezers you have to unclip the clips into the red rectangles.
    • Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
  4. Casio SPF-40 2273 Battery Replacement: étape 4, image 1 de 3 Casio SPF-40 2273 Battery Replacement: étape 4, image 2 de 3 Casio SPF-40 2273 Battery Replacement: étape 4, image 3 de 3
    • Extract the battery leveraging with the tweezers.
    • Keep attention to the golden springs again!
    • The clip, holding down the central batteries, completely removes
5 autres ont terminé cette réparation.
Acn0w
Membre depuis le 09/20/18
12 057 Réputation
1 tutoriel rédigé
3 commentaires
cannot see the “Golden Springs”. Where are they? Thank you
mike.malapascua - Réponse
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 42
30 derniers jours : 137
Total : 9,290
