Aller au contenu principal
Casio WK-220 White Keys Replacement
Ce dont vous avez besoin
  1. Casio WK-220 White Keys Replacement, White Keys: étape 1, image 1 de 2 Casio WK-220 White Keys Replacement, White Keys: étape 1, image 2 de 2
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 White Keys Replacement: étape 2, image 1 de 2 Casio WK-220 White Keys Replacement: étape 2, image 2 de 2
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 White Keys Replacement: étape 3, image 1 de 1
    • Turn device around so keys are face-up
  4. Casio WK-220 White Keys Replacement: étape 4, image 1 de 2 Casio WK-220 White Keys Replacement: étape 4, image 2 de 2
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 White Keys Replacement: étape 5, image 1 de 3 Casio WK-220 White Keys Replacement: étape 5, image 2 de 3 Casio WK-220 White Keys Replacement: étape 5, image 3 de 3
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 White Keys Replacement: étape 6, image 1 de 3 Casio WK-220 White Keys Replacement: étape 6, image 2 de 3 Casio WK-220 White Keys Replacement: étape 6, image 3 de 3
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
Alexa
Membre depuis le 01/24/17
687 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 10-2, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 membres
6 tutoriels rédigés
Un commentaire
Hi. Will this work for broken keys please?
Deborah - EDEN Henderson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 17
Total : 1,561
