Ce dont vous avez besoin
Étape 1 Cassida Counterfeit Detector Disassembly
Attention : les étapes 1 à 6 sont issues d'un tutoriel marqué comme en cours.
Remove the rubber legs.
Get your solder iron and set it to 660 deg Fahrenheit.
Solid core wire is easier to use than standard.
Desolder the contact point for the wire by pressing the hot iron to the contact point until the solder flows and the cable can be pulled from the board.
For more detailed help with soldering and desoldering, check out this handy guide for tips and best practices.
