Aller au contenu principal
Ceiling Fan Pull Chain Switch Replacement
Ce dont vous avez besoin
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: étape 1, image 1 de 2 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: étape 1, image 2 de 2
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: étape 2, image 1 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 2, image 2 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 2, image 3 de 3
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: étape 3, image 1 de 2 Ceiling Fan Pull Chain Switch Replacement: étape 3, image 2 de 2
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: étape 4, image 1 de 1
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: étape 5, image 1 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 5, image 2 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 5, image 3 de 3
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: étape 6, image 1 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 6, image 2 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 6, image 3 de 3
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: étape 7, image 1 de 1
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: étape 8, image 1 de 2 Ceiling Fan Pull Chain Switch Replacement: étape 8, image 2 de 2
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: étape 9, image 1 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 9, image 2 de 3 Ceiling Fan Pull Chain Switch Replacement: étape 9, image 3 de 3
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: étape 10, image 1 de 2 Ceiling Fan Pull Chain Switch Replacement: étape 10, image 2 de 2
    • Turn the power back on and test the switch to find if it is working or not.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Berkeli Alashov
Membre depuis le 02/25/21
244 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 37
30 derniers jours : 175
Total : 15,901
