Aller au contenu principal
Cen-Tech Seven Function Digital Multimeter Dial Replacement
Ce dont vous avez besoin
  1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Position Device: étape 1, image 1 de 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: étape 2, image 1 de 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: étape 2, image 2 de 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel: étape 3, image 1 de 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: étape 4, image 1 de 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: étape 4, image 2 de 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Motherboard: étape 5, image 1 de 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Locate Dial: étape 6, image 1 de 1
    • The dial is located in the central part of the device.
  7. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Dial: étape 7, image 1 de 1
    • Carefully remove dial from device by lifting upward.
    • Clean existing dial or replace if necessary.
    • Take care not to lose the small ball bearings.
Anna Kihm
Membre depuis le 10/13/14
956 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 1,021
