Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Change the security door cylinder
Ce dont vous avez besoin
    1. Change the security door cylinder, Remove the screw holding the handle: étape 1, image 1 de 1
      • It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
      • Remove the two screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Change the security door cylinder, Remove the handle: étape 2, image 1 de 1
      • Use pry bar carefully pry around, you can remove both sides of the door handle.
      • There is usually a plastic washer between the handle and the door, taking care not to damage it.
      • There will be a metal square shaft connected between the handle. Be careful not to lose it when removing the inside handle because the shaft is inside and outside.
      Demander à FixBot
    3. Change the security door cylinder, Pay attention to the square shaft: étape 3, image 1 de 1
      • Pay attention to the installation direction of this square shaft. Do not knock it off when removing the handle.
      Demander à FixBot
    1. Change the security door cylinder, Remove the lock cylinder: étape 4, image 1 de 1
      • Remove the lock cylinder lock screw.
      • Push the lock cylinder to one side of the door, which side is easy to push.
      • Note that the lock cylinder has different types and installation directions. If you want to change the lock cylinder, observe your lock cylinder side, there is a black lever, some in the middle of the cylinder, some in the side position.
      Demander à FixBot
Please re-install in the reverse order of this guide.
Merci à ces traducteurs :
zh en
100%
irlanda nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Z.Heng
Membre depuis le 04/08/17
3 878 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 56
Total : 3,151
