Aller au contenu principal
Char-Broil Grill Burner Replacement
Ce dont vous avez besoin
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: étape 1, image 1 de 1
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: étape 2, image 1 de 2 Char-Broil Grill Burner Replacement: étape 2, image 2 de 2
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: étape 3, image 1 de 1
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: étape 4, image 1 de 2 Char-Broil Grill Burner Replacement: étape 4, image 2 de 2
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: étape 5, image 1 de 1
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: étape 6, image 1 de 3 Char-Broil Grill Burner Replacement: étape 6, image 2 de 3 Char-Broil Grill Burner Replacement: étape 6, image 3 de 3
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
2 autres ont terminé cette réparation.
Dan
Membre depuis le 10/01/17
155 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S5-G1, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S5-G1, Galliah Fall 2017
MTU-GALLIAH-F17S5G1
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 41
Total : 693
