Aller au contenu principal
Chef's Choice M115 Power Cord Replacement
Ce dont vous avez besoin
  1. Chef's Choice M115 Power Cord Replacement, Case: étape 1, image 1 de 2 Chef's Choice M115 Power Cord Replacement, Case: étape 1, image 2 de 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Cord Replacement: étape 2, image 1 de 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Cord Replacement: étape 3, image 1 de 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Cord Replacement: étape 4, image 1 de 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Cord Replacement, Power Cord: étape 5, image 1 de 2 Chef's Choice M115 Power Cord Replacement, Power Cord: étape 5, image 2 de 2
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Cord Replacement: étape 6, image 1 de 1
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
  7. Chef's Choice M115 Power Cord Replacement: étape 7, image 1 de 1
    • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Zachary Grounds
Membre depuis le 09/17/15
580 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 496
