Aller au contenu principal
Chefman RJ38-V2-35 Repair Temperature Knob Replacement
Ce dont vous avez besoin
  1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement, Temperature Knob: étape 1, image 1 de 1
    • Please be sure that the device is unplugged and remove the frying basket from the device.
    • Orient your device where the both the timer knob and temperature knob are facing you.
    • Slide the plastic opening tool under the temperature knob to lift it up.
    • You can slide your fingers in between the gap and take the temperature knob off.
  2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 2, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the two 4mm screws found under the temperature knob.
    • Place you fingers under the silver top and firmly lift it up.
  3. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 3, image 1 de 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 3, image 2 de 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 3, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the two 3 mm screws found at the top of the black panel.
    • Pop off the top panel of the device with your fingers.
  4. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 4, image 1 de 1
    • Using a pair of scissors, cut off the cable cord that is securing the wire cords.
  5. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 5, image 1 de 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 5, image 2 de 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 5, image 3 de 3
    • Detach the device’s wires from the potentiometer.
  6. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: étape 6, image 1 de 1
    • Replace a new potentiometer to the device.
    • Attach the wires back to the new potentiometer.
Lucas Yi
Membre depuis le 10/29/18
156 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 36
Total : 2,257
