Aller au contenu principal
Chromebook 14-x015wm Keyboard Replacement
Ce dont vous avez besoin
  1. Chromebook 14-x015wm Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Chromebook 14-x015wm Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the small rubber circles over all four corners on the bottom of the chromebook.
    • Remove the three small additional rubber covers along edge of computer with hinge.
    • Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  2. Chromebook 14-x015wm Keyboard Replacement: étape 2, image 1 de 1
    • Flip the laptop back over to the front and open it so that the keyboard is visible.
    • Use the iFixit opening tool to pry off the keyboard by placing the tool in-between the keyboard and the case. Move the tool around all sides until the keyboard separates.
    • The keyboard will likely be difficult to remove.
    • Be careful to avoid pulling on the ribbons that connect the keyboard to the internal components in order to prevent damage.
  3. Chromebook 14-x015wm Keyboard Replacement: étape 3, image 1 de 1
    • Carefully unclip the ribbons under the keyboard to disconnect the keyboard.
    • Replace the keyboard and connect the ribbons to the new keyboard.
    • Press the computer case shut and replace the screws and rubber pads.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Michael Johnson
Membre depuis le 10/25/17
122 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G2, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G2
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 430
