Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
The first steps to access the battery, display cable, and write protect screw on the Asus Chromebook Flip C302.
  1. Turn the Chromebook upside down. You may want to place paper or another soft material between the lid and your work surface, so as not to scratch it.
    • Turn the Chromebook upside down. You may want to place paper or another soft material between the lid and your work surface, so as not to scratch it.
    • Remove the 10 (6.14 mm) case screws with a T4 Torx driver.
  2. Using a spudger (or prying tool, or fingernail), gently lift the feet at the rear of the laptop (near the hinges). Get underneath the pad, then release the adhesive by sweeping in a circular motion.
    • Using a spudger (or prying tool, or fingernail), gently lift the feet at the rear of the laptop (near the hinges). Get underneath the pad, then release the adhesive by sweeping in a circular motion.
    • Store the feet upside down and not sticking to anything―you can likely re-adhere them after replacing the cover.
  3. Use a #00 screwdriver to remove the 3.17 mm screws from beneath the rear feet.
    • Use a #00 screwdriver to remove the 3.17 mm screws from beneath the rear feet.
  4. Using a plastic prying tool (avoid metal, as the case is easily scratched), lift the back cover from the case. The underside of a hinge is a good place to start.
    • Using a plastic prying tool (avoid metal, as the case is easily scratched), lift the back cover from the case. The underside of a hinge is a good place to start.
    • You'll feel the cover give way, but there are loose clips holding the lid on. Work gently around the lid, prying and moving beyond clips when you encounter them.
  5. Pull away the back cover. You now have access to the battery, the write-protect screw, and other components.
    • Pull away the back cover. You now have access to the battery, the write-protect screw, and other components.
Kevin Purdy
Membre depuis le 11/04/2019
2 116 Réputation
4 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
135 membres
15 012 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 80
Total : 1,550
