Introduction
If your battery is starting to go out here is a guide which will show you how to throw in a new one.
Ce dont vous avez besoin
Flip your Chromebook Pixel over onto its back
Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
Using a small Philips screwdriver, remove the four screws under the pads
Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
Gently pull up from the front of the laptop and open it up like a clamshell
Locate the write protect screw
Remove it and you can begin flashing your BIOS!
You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
Pull the battery toward you to remove it
Make sure that the wattage and voltage matches the values of the old battery
Follow these steps in reverse and turn on the Pixel.
If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
8 autres ont terminé cette réparation.
2 commentaires
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
