Aller au contenu principal
Chromo Inc. T2 Internal Speaker Replacement
Ce dont vous avez besoin
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: étape 1, image 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: étape 1, image 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: étape 1, image 3 de 3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: étape 2, image 1 de 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: étape 3, image 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: étape 3, image 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: étape 3, image 3 de 3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: étape 4, image 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: étape 4, image 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: étape 4, image 3 de 3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Ismael DeLuna
Membre depuis le 01/21/15
637 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 15-1, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 218
