Aller au contenu principal
Chromo Inc. T2 Motherboard Replacement
Ce dont vous avez besoin
  1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: étape 1, image 1 de 3 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: étape 1, image 2 de 3 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: étape 1, image 3 de 3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Motherboard Replacement, Turn it around: étape 2, image 1 de 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: étape 3, image 1 de 2 Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: étape 3, image 2 de 2
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: étape 4, image 1 de 2 Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Motherboard Replacement: étape 5, image 1 de 2 Chromo Inc. T2 Motherboard Replacement: étape 5, image 2 de 2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  6. Chromo Inc. T2 Motherboard Replacement: étape 6, image 1 de 3 Chromo Inc. T2 Motherboard Replacement: étape 6, image 2 de 3 Chromo Inc. T2 Motherboard Replacement: étape 6, image 3 de 3
    • Using your soldering iron, desolder the six wires on the side of the logic board.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  7. Chromo Inc. T2 Motherboard Replacement: étape 7, image 1 de 2 Chromo Inc. T2 Motherboard Replacement: étape 7, image 2 de 2
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  8. Chromo Inc. T2 Motherboard Replacement: étape 8, image 1 de 1
    • Your motherboard is now ready for replacement!
Ismael DeLuna
Membre depuis le 01/21/15
637 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 15-1, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 647
