Aller au contenu principal
Chumby One LCD Screen Replacement
Ce dont vous avez besoin
  1. Chumby One LCD Screen Replacement, Chassis: étape 1, image 1 de 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: étape 2, image 1 de 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: étape 3, image 1 de 1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: étape 4, image 1 de 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: étape 5, image 1 de 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: étape 6, image 1 de 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: étape 8, image 1 de 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: étape 9, image 1 de 1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: étape 10, image 1 de 1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: étape 11, image 1 de 1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: étape 12, image 1 de 1
    • Remove the LCD screen from the outer case using a plastic opening tool.
Jordan Houchins
Membre depuis le 03/27/17
401 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S3-G3, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 223
