Aller au contenu principal
Chumby One Speaker Replacement
Ce dont vous avez besoin
  1. Chumby One Speaker Replacement, Chassis: étape 1, image 1 de 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Speaker Replacement: étape 2, image 1 de 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Speaker Replacement: étape 3, image 1 de 1
    • Remove the back and bottom cover.
  4. Chumby One Speaker Replacement: étape 4, image 1 de 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Speaker Replacement: étape 5, image 1 de 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Speaker Replacement: étape 6, image 1 de 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Speaker Replacement: étape 7, image 1 de 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Speaker Replacement: étape 8, image 1 de 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Speaker Replacement: étape 9, image 1 de 1
    • Remove the inner components from the outer shell.
  10. Chumby One Speaker Replacement, Speaker: étape 10, image 1 de 1
    • Remove the speaker wire connector from the motherboard.
  11. Chumby One Speaker Replacement: étape 11, image 1 de 2 Chumby One Speaker Replacement: étape 11, image 2 de 2
    • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
  12. Chumby One Speaker Replacement: étape 12, image 1 de 1
    • Remove the speaker.
Jordan Houchins
Membre depuis le 03/27/17
401 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S3-G3, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 178
