Ce dont vous avez besoin
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
Completely remove the motherboard.
Set aside the front cover.
Flip over the motherboard.
Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
Flip over the motherboard so the screen faces up.
Carefully slide the battery off of the motherboard.
