Aller au contenu principal
Cirago M9030 IDE Connector Replacement
Ce dont vous avez besoin
  1. Cirago M9030 IDE Connector Replacement, Cover: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 IDE Connector Replacement: étape 2, image 1 de 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 IDE Connector Replacement: étape 3, image 1 de 2 Cirago M9030 IDE Connector Replacement: étape 3, image 2 de 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 IDE Connector Replacement, Hard Drive: étape 4, image 1 de 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 IDE Connector Replacement: étape 5, image 1 de 3 Cirago M9030 IDE Connector Replacement: étape 5, image 2 de 3 Cirago M9030 IDE Connector Replacement: étape 5, image 3 de 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 IDE Connector Replacement: étape 6, image 1 de 3 Cirago M9030 IDE Connector Replacement: étape 6, image 2 de 3 Cirago M9030 IDE Connector Replacement: étape 6, image 3 de 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 IDE Connector Replacement, IDE Connector: étape 7, image 1 de 2 Cirago M9030 IDE Connector Replacement, IDE Connector: étape 7, image 2 de 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 IDE Connector Replacement: étape 8, image 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 IDE Connector Replacement: étape 9, image 1 de 2 Cirago M9030 IDE Connector Replacement: étape 9, image 2 de 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 IDE Connector Replacement: étape 10, image 1 de 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 IDE Connector Replacement: étape 11, image 1 de 2 Cirago M9030 IDE Connector Replacement: étape 11, image 2 de 2
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
To reassemble your device, follow these instructions in reverse order. Once you've replaced the IDE connector and reassembled your Cirago M9030, your device should be able to detect hard drives properly again. If everything is connected correctly, your repair is complete. Great job!
Ryan Sutardji
Membre depuis le 06/29/12
171 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-4, Regan SU 2012 Membre de l'équipe Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 24
Total : 1,036
