Aller au contenu principal
Circuit Board Housing Removal
Ce dont vous avez besoin
  1. Circuit Board Housing Removal, Battery: étape 1, image 1 de 2 Circuit Board Housing Removal, Battery: étape 1, image 2 de 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: étape 2, image 1 de 2 Circuit Board Housing Removal: étape 2, image 2 de 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: étape 3, image 1 de 3 Circuit Board Housing Removal, Circuit Board Housing: étape 3, image 2 de 3 Circuit Board Housing Removal, Circuit Board Housing: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: étape 4, image 1 de 2 Circuit Board Housing Removal: étape 4, image 2 de 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: étape 5, image 1 de 2 Circuit Board Housing Removal: étape 5, image 2 de 2
    • Remove the back cover completely from the phone.
Jonathan Flowers
Membre depuis le 10/18/13
607 Réputation
6 tutoriels rédigés
Équipe
Clemson, Team 14-7, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 622
