Aller au contenu principal
Circuit Board
Ce dont vous avez besoin
  1. Circuit Board, Battery: étape 1, image 1 de 2 Circuit Board, Battery: étape 1, image 2 de 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board: étape 2, image 1 de 2 Circuit Board: étape 2, image 2 de 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board, Circuit Board Housing: étape 3, image 1 de 3 Circuit Board, Circuit Board Housing: étape 3, image 2 de 3 Circuit Board, Circuit Board Housing: étape 3, image 3 de 3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board: étape 4, image 1 de 2 Circuit Board: étape 4, image 2 de 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board: étape 5, image 1 de 2 Circuit Board: étape 5, image 2 de 2
    • Remove the back cover completely from the phone.
  6. Circuit Board, Circuit Board: étape 6, image 1 de 1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. Circuit Board: étape 7, image 1 de 2 Circuit Board: étape 7, image 2 de 2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
Jonathan Flowers
Membre depuis le 10/18/13
607 Réputation
6 tutoriels rédigés
Équipe
Clemson, Team 14-7, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 498
