Aller au contenu principal
Cisco Meraki MC74-HW Sensor Cover Replacement
Ce dont vous avez besoin
  1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: étape 1, image 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: étape 1, image 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: étape 1, image 3 de 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Sensor Cover Replacement: étape 2, image 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 2, image 2 de 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Sensor Cover Replacement: étape 3, image 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 3, image 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 3, image 3 de 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Sensor Cover Replacement: étape 4, image 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 4, image 2 de 2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: étape 5, image 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Sensor Cover Replacement: étape 6, image 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 6, image 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: étape 6, image 3 de 3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
  7. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: étape 7, image 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: étape 7, image 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: étape 7, image 3 de 3
    • Remove the two 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the sensor cover.
Anthony Kairouz
Membre depuis le 10/18/21
253 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Membre de l'équipe UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 150
