Introduction
This guide shows how to remove and replace the drive pulley.
Note: The pulley can be hard to remove and requires a suitably sized gear puller to extract it.
Note: The pulley bolt may be heavily seized on with thread-lock. You may need to use a blowtorch to heat up the bolt in order to soften the thread-lock.
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Push down on the main handle to tilt the over seeder back on its rear wheels.
Place some weights on the handle, or tie the handle down, to prevent the machine from falling forward.
Remove the four lock nuts securing the belt guard:
Two 1/2" lock nuts
Two 7/16" lock nuts
Place a block of wood to jam the blades so they don't rotate forward, allowing you to unscrew the pulley bolt.
Lubricate the axle and key with machine oil.
Set the square key in the pulley first, then align the pulley onto the axle. This makes it slightly easier to hammer the pulley in place.
Hammer the pulley in place with a rubber mallet.
Before you tighten the set screws, make sure that the drive pulley's belt path aligns with the idler pulley.
