Introduction
Si votre clavier clignote en rouge et refuse de s’allumer (cela peut arriver par alternance avant de devenir définitif) c’est probablement qu’il faut changer les batteries de ce dernier.
Une autre panne - plus sérieuse - peut être un câble débranché (toujours au niveau de la batterie).
Ce dont vous avez besoin
Une fois la trappe des piles ouvertes, remplacez les piles originales par des nouvelles piles rechargeables.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
7 commentaires
If the keyboard doesn’t work with the new batteries, doesn’t charge the batteries, or doesn’t communicate with the unifying receiver, a mainboard replacement may be necessary. The replacement circuit board can be purchased via eBay. Search eBay for “210-000797” which is the code for the PCB.
Actually, if the battery change doesn’t work, it’s more probable that the issue is a cable disconnected around the location of the batteries. A little piece of tape on the cable will fix it!
They changed the design. The batteries are no longer accessible through the slot. They want you to trash it and get another one. Can you guys do another teardown for the new eco-destructive design?
yeah I have design purchased from bestbuy around 2015 or 16 with hidden battery and 50 steps to replace.
This tutorial on how to replace the old k800 version batteries easily accessible under the simple cover plate is sofa king useless :)
ok maybe people actually need tutorials on how to replace batteries in remotes or flashlights, my bad.
jimi -
If you’re looking for a solution in the exact same model, you can still remove the entire backside of the keyboard and replace batteries :) . It’s a bit more complicated, but I did it and it’s fine. You can find videos online about how to do it.
