Aller au contenu principal
Cleaning the Fan Blades
Ce dont vous avez besoin
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): étape 1, image 1 de 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Cleaning the Fan Blades: étape 2, image 1 de 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Cleaning the Fan Blades: étape 3, image 1 de 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Cleaning the Fan Blades: étape 4, image 1 de 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Cleaning the Fan Blades: étape 5, image 1 de 2 Cleaning the Fan Blades: étape 5, image 2 de 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Cleaning the Fan Blades, Fan Blades: étape 6, image 1 de 1
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
Vivian Fong
Membre depuis le 09/26/12
97 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-46, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 89
Total : 10,213
