Aller au contenu principal
Cleaning the Skullcandy Mix Master DJ Adjustment Slider
Ce dont vous avez besoin
  1. Cleaning the Skullcandy Mix Master DJ Adjustment Slider, Cleaning the Skullcandy Mix Master DJ Adjustment Slider: étape 1, image 1 de 1
    • Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
  2. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: étape 2, image 1 de 1
    • Rotate the headphones so that one of the speaker cups are facing you. Remove the four Phillips 3 mm screws along the headband cover.
  3. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: étape 3, image 1 de 1
    • Gently remove the cover from the headband.
    • Removing the cover too fast could break the thin wire within the headband.
  4. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: étape 4, image 1 de 1
    • Using a moist Q-tip or small towel, carefully wipe the inside of the headband sheath.
    • Be careful when cleaning to avoid damaging to the wire.
    • Do not use cleaning solvents. They may cause the plastic to break down.
Seth Blackburn
Membre depuis le 03/30/15
110 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-3, Shastany Spring 2015 Membre de l'équipe UMass Dartmouth, Team 1-3, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 7
Total : 475
