Aller au contenu principal
Cobra 29 LTD Classic Outer Cover Replacement
Ce dont vous avez besoin
  1. Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: étape 1, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: étape 1, image 2 de 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Outer Cover Replacement: étape 2, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: étape 2, image 2 de 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: étape 3, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: étape 3, image 2 de 2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Outer Cover Replacement: étape 4, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: étape 4, image 2 de 2
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Outer Cover Replacement, Microphone: étape 5, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Microphone: étape 5, image 2 de 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Outer Cover Replacement: étape 6, image 1 de 1
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: étape 7, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: étape 7, image 2 de 2
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Outer Cover Replacement: étape 8, image 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 8, image 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 8, image 3 de 3
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Outer Cover Replacement: étape 9, image 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 9, image 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 9, image 3 de 3
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Outer Cover Replacement: étape 10, image 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: étape 10, image 2 de 2
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Outer Cover Replacement: étape 11, image 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 11, image 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: étape 11, image 3 de 3
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
2 autres ont terminé cette réparation.
Chase
Membre depuis le 10/20/13
267 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-37, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 1,653
