Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
  • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
  • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
  • It is not required to remove the other seven screws in the middle between the I/O ports.
Ajouter un commentaire
Position the DVD player so that the back is facing you
  • Position the DVD player so that the back is facing you
  • Grab underneath the sides of the DVD player and lift the front of it upwards.
  • Carefully pull the top of the casing off
  • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
  • Remove the wire from the circuit board.
  • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
  • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  • Position the DVD player so that the back panel is facing you.
  • Remove the three wires with the white pin adapters from the golden circuit board.
  • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
  • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  • Position the DVD player so that the front is facing you.
  • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
  • Grab the sides of the back panel and remove it from the DVD player.
  • Remove the two 1cm screws that are circled in red.
  • De-solder the electrical components contained in the red rectangles from the green circuit board, which is the second one you removed.
  • Each red rectangle contains the electrical components for a specific group of I/O ports
Andrew
Membre depuis le 22/10/2014
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 114
