Aller au contenu principal
Coby DVD-R11000 Outer Casing Replacement
Ce dont vous avez besoin
  1. Coby DVD-R11000 Outer Casing Replacement, Outer Casing: étape 1, image 1 de 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: étape 1, image 2 de 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: étape 1, image 3 de 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Outer Casing Replacement: étape 2, image 1 de 3 Coby DVD-R11000 Outer Casing Replacement: étape 2, image 2 de 3 Coby DVD-R11000 Outer Casing Replacement: étape 2, image 3 de 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
Andrew
Membre depuis le 10/22/14
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 140
