Aller au contenu principal
Coby DVD209 4-Pin Ribbon Cable Replacement
Ce dont vous avez besoin
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: étape 1, image 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: étape 1, image 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: étape 1, image 3 de 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: étape 2, image 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: étape 2, image 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: étape 2, image 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: étape 3, image 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: étape 3, image 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: étape 3, image 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: étape 4, image 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: étape 4, image 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: étape 4, image 3 de 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Yufay Chow
Membre depuis le 01/23/12
92 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 10-36, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,007
