Aller au contenu principal
Coby DVD209 Circuit Board for Buttons Replacement
Ce dont vous avez besoin
  1. Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: étape 1, image 1 de 3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: étape 1, image 2 de 3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuit Board for Buttons Replacement: étape 2, image 1 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 2, image 2 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 2, image 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuit Board for Buttons Replacement: étape 3, image 1 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 3, image 2 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 3, image 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: étape 4, image 1 de 2 Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: étape 4, image 2 de 2
    • Take the top portion of the DVD player and orient the device as shown in the first picture.
    • Remove the four 0.2" screws circled in red.
  5. Coby DVD209 Circuit Board for Buttons Replacement: étape 5, image 1 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 5, image 2 de 3 Coby DVD209 Circuit Board for Buttons Replacement: étape 5, image 3 de 3
    • Losen the screw circled in red.
    • The screw will not come out of the plastic knob.
    • Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
Yufay Chow
Membre depuis le 01/23/12
92 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 10-36, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 445
