Aller au contenu principal
Coby DVD209 Fuse Replacement
Ce dont vous avez besoin
  1. Coby DVD209 Fuse Replacement, The bottom portion of the DVD player: étape 1, image 1 de 3 Coby DVD209 Fuse Replacement, The bottom portion of the DVD player: étape 1, image 2 de 3 Coby DVD209 Fuse Replacement, The bottom portion of the DVD player: étape 1, image 3 de 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Fuse Replacement: étape 2, image 1 de 3 Coby DVD209 Fuse Replacement: étape 2, image 2 de 3 Coby DVD209 Fuse Replacement: étape 2, image 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Fuse Replacement: étape 3, image 1 de 3 Coby DVD209 Fuse Replacement: étape 3, image 2 de 3 Coby DVD209 Fuse Replacement: étape 3, image 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Fuse Replacement, 4-Pin Ribbon Cable: étape 4, image 1 de 3 Coby DVD209 Fuse Replacement, 4-Pin Ribbon Cable: étape 4, image 2 de 3 Coby DVD209 Fuse Replacement, 4-Pin Ribbon Cable: étape 4, image 3 de 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
  5. Coby DVD209 Fuse Replacement, Circuitboards: étape 5, image 1 de 3 Coby DVD209 Fuse Replacement, Circuitboards: étape 5, image 2 de 3 Coby DVD209 Fuse Replacement, Circuitboards: étape 5, image 3 de 3
    • Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously.
    • Lift the power port out of the its slot.
  6. Coby DVD209 Fuse Replacement: étape 6, image 1 de 3 Coby DVD209 Fuse Replacement: étape 6, image 2 de 3 Coby DVD209 Fuse Replacement: étape 6, image 3 de 3
    • Remove the four 5mm screws circled in red.
    • Place the blue plastic tool opener underneath the circuitboard and lift up gently.
  7. Coby DVD209 Fuse Replacement: étape 7, image 1 de 3 Coby DVD209 Fuse Replacement: étape 7, image 2 de 3 Coby DVD209 Fuse Replacement: étape 7, image 3 de 3
    • Unplug the two, 3-pin ribbon cables, which are attached to the circuitboard.
    • For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device.
  8. Coby DVD209 Fuse Replacement: étape 8, image 1 de 3 Coby DVD209 Fuse Replacement: étape 8, image 2 de 3 Coby DVD209 Fuse Replacement: étape 8, image 3 de 3
    • Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports.
  9. Coby DVD209 Fuse Replacement, Fuse: étape 9, image 1 de 1
    • Desolder the items circled in red from the first circuit board you removed.
Carlos Mena
Membre depuis le 01/23/12
30 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-36, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 1,851
