Aller au contenu principal
Coby DVD209 The bottom portion of the DVD player Replacement
Ce dont vous avez besoin
  1. Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: étape 1, image 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: étape 1, image 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 The bottom portion of the DVD player Replacement: étape 2, image 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: étape 2, image 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: étape 2, image 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 The bottom portion of the DVD player Replacement: étape 3, image 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: étape 3, image 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: étape 3, image 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Kyle VanAllen
Membre depuis le 01/20/12
70 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-36, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 344
