Introduction
If your Coby Kyros MID9042 isn't holding a charge or you know that the battery is broken or needs to be replaced, use this guide to replace the battery. This battery provides power to the entire tablet and a faulty or damaged battery will render the tablet useless. before using this guide be sure to unplug the device and make sure the charging port is clear of any debris. Make sure most of the dust and debris is removed with a brush or cloth. Also, make sure to completely power off the device
Ce dont vous avez besoin
Remove anti-slip pads from all four corners of the back of the device with a nylon spudger.
Remove the four 1/8" screws using a Phillips #0 screwdriver.
2 autres ont terminé cette réparation.
