Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Coleman CT200U-AB Mini Bike Throttle Assembly Replacement
Ce dont vous avez besoin
  1. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement, Throttle Assembly: étape 1, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement, Throttle Assembly: étape 1, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement, Throttle Assembly: étape 1, image 3 de 3
    • Switch the fuel valve OFF, and place the bike on a level surface before starting.
    • Remove the seat for better access.
    • Two 8mm bolts are holding the seat down to the frame (Picture 2).
    • Use the 8mm wrench to remove the bolts, then lift the seat to remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 2, image 1 de 1
    • Once the seat is off, you can see the spark plug wire.
    • Disconnect the spark plug wire as a safety precaution to disable the ignition. Grasp the wire boot, not the wire itself, and pull gently to disconnect it from the spark plug.
    Demander à FixBot
  3. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 3, image 1 de 2 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 3, image 2 de 2
    • Inspect the throttle assembly. Check for visible damage to the throttle cable, grip, and housing. Look for frayed cables or sticking in the throttle twist mechanism.
    • This throttle cable is visibly frayed and must be replaced.
    Demander à FixBot
  4. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 4, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 4, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 4, image 3 de 3
    • Remove the screw using a Phillips #00 screwdriver.
    • Slide off the rubber grip.
    • Take off the throttle clamp to expose the throttle cable sheath.
    Demander à FixBot
  5. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 5, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 5, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 5, image 3 de 3
    • Remove the nut and screw securing the throttle cable to the carburetor linkage.
    • Pull the cable out of the throttle assembly.
    Demander à FixBot
  6. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 6, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 6, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 6, image 3 de 3
    • Lay out the new throttle kit in front of you. Make sure that you have a throttle cable, clamp, and grip.
    • Use the screwdriver to separate the two halves of the throttle clamp.
    Demander à FixBot
  7. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 7, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 7, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 7, image 3 de 3
    • Install the new wire into the new throttle.
    • Insert the ferrule into the throttle clamp.
    Demander à FixBot
  8. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 8, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 8, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 8, image 3 de 3
    • Insert the ferrule into the throttle housing.
    • Hook the barrel into the grip drum.
    • Check that the cable rides in the molded channel.
    Demander à FixBot
  9. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 9, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 9, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 9, image 3 de 3
    • Prepare the grip and the throttle for installation on the handlebars.
    • Apply a drop of thread‑locker to each bolt. Clamp the two housing halves together.
    • Slide the grip onto the handlebar.
    Demander à FixBot
  10. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 10, image 1 de 2 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 10, image 2 de 2
    • Secure the throttle assembly onto the handlebars.
    • Reinstall the screws and tighten them with a screwdriver.
    Demander à FixBot
  11. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 11, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 11, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 11, image 3 de 3
    • Attach the cable sleeve to the throttle assembly on the engine.
    • Place the throttle cable into the throttle assembly located on the engine.
    • Tighten the screws to secure the throttle cable.
    Demander à FixBot
  12. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 12, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 12, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 12, image 3 de 3
    • Adjust the throttle tension. Ensure that the throttle snaps back properly when released.
    • Adjust the cable tension if necessary using the adjustment screw near the carburetor. Refer back to Step 11 if needed.
    Demander à FixBot
  13. Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 13, image 1 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 13, image 2 de 3 Coleman CT200U-AB Mini Bike Throttle Assembly Replacement: étape 13, image 3 de 3
    • Reattach the spark plug wire to the spark plug.
    • Reinstall the seat and tighten the bolts.
    • Twist the throttle to make sure it works properly.
    Demander à FixBot
The throttle replacement is complete. The throttle should move smoothly and snap back when released.
4 autres ont terminé cette réparation.
Kaleb Tessema
Membre depuis le 02/03/25
262 Réputation
1 tutoriel rédigé
Équipe
York University, Team 4-8, Woodhouse Winter 2025 Membre de l'équipe York University, Team 4-8, Woodhouse Winter 2025
YORK-WOODHOUSE-W25S4G8
2 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 65
30 derniers jours : 303
Total : 3,488
