Aller au contenu principal
ComNet Ericsson Panther 600P Display Replacement
Ce dont vous avez besoin
  1. ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: étape 1, image 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: étape 1, image 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: étape 1, image 3 de 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Display Replacement, Antenna: étape 2, image 1 de 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Display Replacement, Dials: étape 3, image 1 de 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Display Replacement, Exterior Case: étape 4, image 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: étape 4, image 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: étape 4, image 3 de 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: étape 5, image 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: étape 5, image 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: étape 5, image 3 de 3
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Display Replacement, Ribbon: étape 6, image 1 de 2 ComNet Ericsson Panther 600P Display Replacement, Ribbon: étape 6, image 2 de 2
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Display Replacement, Screen: étape 7, image 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Screen: étape 7, image 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Screen: étape 7, image 3 de 3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
Daniel
Membre depuis le 01/13/15
109 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 10
Total : 219
